Guest supercoupe5 Posted August 7, 2007 Share Posted August 7, 2007 i have a column shifter and want to go to a overdrive trans. do i have any options on this. dont really want to put a console in it if i dont have to. thanks dave Quote Link to comment Share on other sites More sharing options...
monte70car Posted August 7, 2007 Share Posted August 7, 2007 dave i know the part u need let me find the part # and ill pm it to u here is a link dave http://www.julianos.com/lokar_column.html Quote Link to comment Share on other sites More sharing options...
Grease Posted August 8, 2007 Share Posted August 8, 2007 Supercoupe you should be able to install the cross shaft from a donor car which had a 200 or 700 trans ( the shaft from the frame to the trans) . Then your only problem would be the PRNDL1 in the dash is not exzactly correct. But the shifting will be fine . I havnet seen a PRNDdL1 for a column . Most likely someone sells one . You might try BowtieOverdrive.com Quote Link to comment Share on other sites More sharing options...
