Guest TLP Posted February 9, 2008 Share Posted February 9, 2008 Has any body used or know any one that has used the chevy fast burn al/heads. if so how did they like them? Link to comment Share on other sites More sharing options...
Guest 72yellowmc Posted February 10, 2008 Share Posted February 10, 2008 i asume your are talking about the vortec fast burn heads...... Link to comment Share on other sites More sharing options...
Guest TLP Posted February 10, 2008 Share Posted February 10, 2008 Yes the aluminum one's Link to comment Share on other sites More sharing options...
680HPStroker Posted February 13, 2008 Share Posted February 13, 2008 Know a few people who have them and liked them once they got the right cam. These heads are especially finiky about cam grind. I'm not sure what one you need, but Comp Cams cam help line will. If you are on a budget I'd go with Vortec iron heads with the good parts in them and call it a day. There are some pretty good mills out there running these heads and they are cheap. Link to comment Share on other sites More sharing options...
Guest TLP Posted February 15, 2008 Share Posted February 15, 2008 Thanks, I seen where I could get a set about 450 cheaper than a set of AFR 195 E'S I did not know much about them. If I go that route I guess I will go AFR. Link to comment Share on other sites More sharing options...
680HPStroker Posted February 15, 2008 Share Posted February 15, 2008 You can't go wrong with AFR. I use their BBC 315CNC heads and love them. I put down 534hp to the wheels on pump gas and I still think that these heads still have enough left in them to put down another 15-20 wheel HP. Until I personally see a set of Dart heads beat the power numbers I'm a AFR fan for life. Most of the AFR fans are on the west coast and most people from the east are Dart nuts. Weird. Link to comment Share on other sites More sharing options...
Heckeng Posted February 15, 2008 Share Posted February 15, 2008 I have a buddy who just got a set of the AFR 195 Eliminator heads. All I can say is WOW! They look phenomenal. You will not be disappointed if you order the AFRs. Although the Vortecs are a great option too. Scott Link to comment Share on other sites More sharing options...
