Randy Posted January 6, 2021 Share Posted January 6, 2021 Hi I'm having 2 issues with my tach/gauge conversion. The temp gauge starts at 100 immediately rises slowly to 250 The tach reads 500 at idle but increases by 100 rpms as you turn on parking lights, headlights and blower Also the tach is very sensitive to any gas pedal movement, half throttle will run the tach almost to redline Any help would be great Thanks Randy Quote Link to comment Share on other sites More sharing options...
overdrive Posted January 8, 2021 Share Posted January 8, 2021 You should probably call the gauge manufacturer to get tech help. The temp problem could be the wrong sending unit. That's one possibility. The tach must get the signal from the distributor. It seems like it doesn't. Dan Quote Link to comment Share on other sites More sharing options...
