Reaper Posted April 19, 2008 Share Posted April 19, 2008 OK... I got the trans in and mostly bolted up... I finished the rear end and put it back in and put the car on the ground to see what the stance looks like now because the rear springs I put on were a lot shorter than the stock ones... (It sits about level now..) Anyway to the problem... When the trans was out of the car I could turn the shaft with no problem... now that its in the car and all bolted up it wont turn easy going counter clock wise and wont turn at all clock wise... this is the way it is in every gear.... Do you guys have any ideas of whats goin in? Thanks, Tom Quote Link to comment Share on other sites More sharing options...
kc8oye Posted April 19, 2008 Share Posted April 19, 2008 isn't that normal due to the action of the lo-roller clutch on the output shaft? Quote Link to comment Share on other sites More sharing options...
