Guest Posted December 8, 2005 Share Posted December 8, 2005 Anyone have experience with Richman rear gears. I have been told by some that they run hot and noisey. Is that true? While Richman are "harder"and stronger than OEM some say OEM are quiet. Also, are Yukon quiet? Thanks Quote Link to comment Share on other sites More sharing options...
Andreas Posted December 8, 2005 Share Posted December 8, 2005 I guess you mean Richmond Gears? I run a set of 3.73 Richmonds in my 71 and did not find them noisier than any other gearset... Quote Link to comment Share on other sites More sharing options...
Guest Posted December 8, 2005 Share Posted December 8, 2005 Andreas, right richmond (S/P). Thanks for input. I have OEM gear set now so I am concerned about the change ie noise. Richard Quote Link to comment Share on other sites More sharing options...
Guest Posted December 9, 2005 Share Posted December 9, 2005 331's in mine and no noise or vibes, Bob Quote Link to comment Share on other sites More sharing options...
Guest Posted December 9, 2005 Share Posted December 9, 2005 I had Richmond 3:73's in my '69 Cutlass. I didn't notice any sound difference. Quote Link to comment Share on other sites More sharing options...
big gear head Posted December 9, 2005 Share Posted December 9, 2005 Most Richmond gears that make noise are simply set up wrong. Either the backlash or pinion depth is not correct. I have had a few problems with Richmond gears, but I can't say that they have more problems than any other manufacturer. I use mostly Motive Gear and US Gear. Quote Link to comment Share on other sites More sharing options...
Guest Posted December 9, 2005 Share Posted December 9, 2005 I have 4.56 Richmond gears in my Monte. i do not notice any more noise than the stock ones. Of course I can't hear much over the exhaust. Big J Quote Link to comment Share on other sites More sharing options...
Guest Posted December 9, 2005 Share Posted December 9, 2005 Thanks guy. Sounds like Richmond gets the thumbs up. Quote Link to comment Share on other sites More sharing options...
John Burns Posted December 10, 2005 Share Posted December 10, 2005 Most Richmond gears that make noise are simply set up wrong. Either the backlash or pinion depth is not correct. I have had a few problems with Richmond gears, but I can't say that they have more problems than any other manufacturer. I use mostly Motive Gear and US Gear. So true- Richmond gears are ok, but set them up wrong and they'll make noise. Setting up gears is no simple matter, either. Around here, you either pay a fortune to have them set up correctly or do it cheap (by a "performance shop") and they're noisey. But hey, who cares- the exhaust drone will cover it up.... It can actually start to make sense $$ to just buy a complete new rear. Quote Link to comment Share on other sites More sharing options...
Guest Posted December 10, 2005 Share Posted December 10, 2005 jrb70454 Thanks for the input. I priced Moser complete rear. It comes to about $2200. New posi,gears, bearings and install kit goes for about $1200 instlled.Big Difference! Do you know of any supplier of new stock 10 or 12 bolt rears with posi? Thanks. RichMonte Quote Link to comment Share on other sites More sharing options...
big gear head Posted December 10, 2005 Share Posted December 10, 2005 I sent you an email. Quote Link to comment Share on other sites More sharing options...
