TommyP Posted October 28, 2009 Share Posted October 28, 2009 Well I guess that I have another question. This question has to do with my gas tank and gas cap. I removed my gas tank several years back and had a sump welded on the tank so I could run a bigger fuel line. When I reinstalled the tank I disconnected and plugged all the stock lines going into the tank. I think there is one line on each side and three in the middle. I wasn’t too worried about a vent because the gas cap that I’ve been using is a loose fitting locking type that came with the car. Well I want to switch over to a tighter fitting cap because if I get the tank too full now gas leaks out around the cap when accelerating. I ended up getting a gas cap a while back off eBay it’s a Stant G 807 I’m not sure if I need to vent the tank now to use this cap. The cap says on it Pressure and Vacuum so I think that it’s a sealed one. When I search it on the Stant’s web site I can’t get anything to come up maybe because it’s so old. Sorry for being so long winded. Tom Quote Link to comment Share on other sites More sharing options...
dbreese Posted October 28, 2009 Share Posted October 28, 2009 I can solve the problem........slow down!!! J/K Tom I think you can use some type of one way vent that you can plumb into the one of the original vent/emissions tank fittings. I think Jegs or Summit has something you can use or one of the places that cater to the roundy round guys. I have heard of some people that have drilled a very small hole in the cap to help vent. David Quote Link to comment Share on other sites More sharing options...
TommyP Posted October 28, 2009 Author Share Posted October 28, 2009 David, I'm not sure slowing down is a option Part of the reason that I'm changing it is so I can get more gas in the tank for long distance driving like maybe a slow fall color tour, or maybe dragweek........ Quote Link to comment Share on other sites More sharing options...
kc8oye Posted October 28, 2009 Share Posted October 28, 2009 72 tanks use _NON_ vented caps. you must supply your own vent into the tank somewhere (Any one of those unused fittings will work) i put a hose on one of the fittings and ran it up to the top of my axle arch and secured it to the car.. worked awesome and never gave me trouble. Quote Link to comment Share on other sites More sharing options...
