monte70car Posted December 17, 2009 Share Posted December 17, 2009 We have a stock 350 short block laying around how far could some one bore the block out to? Quote Link to comment Share on other sites More sharing options...
CrazyDavey Posted December 17, 2009 Share Posted December 17, 2009 if you take it more than .060 you're going to get into a bunch of non-standard expensive parts(most only go .030 = 355). I personally don't know anyone who has gone farther than 60.....you have to go with a crank to make them bigger..... Quote Link to comment Share on other sites More sharing options...
Shadow Gray SS Posted December 18, 2009 Share Posted December 18, 2009 I have heard of a SB 454, Mostly stroke I think though. Quote Link to comment Share on other sites More sharing options...
monte70car Posted December 18, 2009 Author Share Posted December 18, 2009 I was thinking of a nice 396 small block was doing some reading on it. Looks like they want a .030 over bore then a 383 crank with .125 on the crank. But there is problems with when clancing the block for the rods. But they make over 850hp :wow: Quote Link to comment Share on other sites More sharing options...
CrazyDavey Posted December 18, 2009 Share Posted December 18, 2009 I was thinking of a nice 396 small block was doing some reading on it. Looks like they want a .030 over bore then a 383 crank with .125 on the crank. But there is problems with when clancing the block for the rods. But they make over 850hp :wow: 850hp would be a pretty radical motor Rob. The shop I use just built a mild 427 with a 671 that made 850 but that was at the flywheel. The crank that is used in most 383's is a sb 400 crank in a .030 over 350 block. You have to notch the pan rails along the bottom of the block to clear the rods. Pretty sure anything bigger than a 406 would require an aftermarket block like dbreese (Dave) just bought. Both the 427 and a 454 I know of were built with a World Products block (they also required special cams because of the raised cam position)... Quote Link to comment Share on other sites More sharing options...
monte70car Posted December 18, 2009 Author Share Posted December 18, 2009 I just dreaming stroker I was reading that link and it dont sound like a 396 small block be worth the money. Here is a link to a 396 small block 396 This is where I was getting the 850hp number from kits Quote Link to comment Share on other sites More sharing options...
dbreese Posted December 18, 2009 Share Posted December 18, 2009 Originally Posted By: monte70car I was thinking of a nice 396 small block was doing some reading on it. Looks like they want a .030 over bore then a 383 crank with .125 on the crank. But there is problems with when clancing the block for the rods. But they make over 850hp :wow: 850hp would be a pretty radical motor Rob. The shop I use just built a mild 427 with a 671 that made 850 but that was at the flywheel. The crank that is used in most 383's is a sb 400 crank in a .030 over 350 block. You have to notch the pan rails along the bottom of the block to clear the rods. Pretty sure anything bigger than a 406 would require an aftermarket block like dbreese (Dave) just bought. Both the 427 and a 454 I know of were built with a World Products block (they also required special cams because of the raised cam position)... 4.200 max bore x max stroke 4.00 x 8 = 443.4 ci. Thats what could be done with the Motown block I have. David David Quote Link to comment Share on other sites More sharing options...
Cali Z28 Posted December 18, 2009 Share Posted December 18, 2009 Stock small block I wouldnt go anything over a 383 or whatever the cubic inch comes out if its at most 60 over. I'd choose the Dart block over the World. Scott Quote Link to comment Share on other sites More sharing options...
