Monte7071 Posted July 6, 2010 Share Posted July 6, 2010 Found this list of RPO codes today. R.P.O. code Part description Years used Special notes 837 Base Corvette coupe 1963-64 867 Base Corvette convertible 1963-64 898 Leather seats Corvette A01 Softray tinted glass 1963- All windows A02 Tinted glass 1963- Windshield only A13 Power door locks A16 Power tailgate release A20 Custom seat belts 1964 A31 Power tailgate release A31 Electric window control A33 Electric tailgate window control A37 Seat belt equipment 1964- A39 Front and Rear Seat Belts 1966- Retractors on front belts A41 Electric front seat control 4 way A42 Electric front seat control 6 way A43 Six way manual seat adjuster A46 Electric driver seat 4 way bucket A47 Seat belts Custom Deluxe A49 Front seat belt w/ retractors 1964- Use with RPO A63 A51 Front bucket seat Astro A52 Front bench seat Astro A53 Front bench seat A62 Front seat belt delete A63 Rear seat belt delete A64 Rear seat belt Custom Deluxe A65 Front bench seat Split type seat w/arm rest A66 Split second seat Station wagon A67 Folding rear seat A68 Rear seat center belt Standard A75 H.D. front seat cushion Low profile type A76 H.D. rear seat A81 Head rests-bucket seats A82 Head rests-bench seat A85 Shoulder harness 1966- Deluxe A90 Electric trunk opener A91 Vacuum trunk opener A93 Vacuum door locks A96 Rear compartment lock AG7 6 way power seat AK1 Seat belts/shoulder harness Custom Deluxe AL4 Front bench seat Special contour-Astro AL5 Rear center seat belt Deluxe AN5 Lateral restraint seat AN7 Swing out strato buckets AO5 Electric seat back lock release AQ2 Electric seat belt lock release 1971 AQ5 Electric seat belt lock release 1970 AS1 Shoulder harness Standard AS2 Headrests Special contour-strato AS4 Rear seat shoulder harness 1968- Deluxe AS5 Rear seat shoulder harness 1968- Standard AT8 Reclining passenger seat AU1 Power door locks 1970- Electric AU2 Power cargo lock Electric AU3 Power door locks Electric B01 Heavy duty body B02 Taxi cab B07 Police car B2M Power steering delete B30 Floor covering B34 H.D. front floor mat B35 H.D. rear floor mat B37 Floor mats B39 Load floor carpet B42 Luggage compartment mat B44 Removable load floor carpet B49 Deluxe carpet floor covering B50 Foam rubber front seat cushion B55 Deluxe front seat cushion B70 Instrument panel pad 1963- B75 Luggage compartment lining B81 Tailgate molding delete Deletes the trim strips B90 Door window moldings B95 Rear panel moldings B96 Wheel well moldings B80 Roof drip molding B84 Body side molding B85 Belt reveal molding B93 Door edge guards BX4 Body side molding Upper BX8 Full body moldings BY3 Headliner BW1 Tailgate ornament delete Deletes stripe or wood grain BW2 Body side molding Deluxe BW6 Custom appearance group CA1 Power roof CB1 Vinyl roof Touring CB7 Vinyl roof CD2 Washer fluid monitor 1970 only Fiber optic fluid level monitor CD3 Electro-tip wipers 1970- CE1 Headlight washers CF1 Skyroof C04 Cabriolet roof CO5 Convertible top Manual CO6 Convertible top Electric C07 Auxilary hardtop CO8 Vinyl roof CO9 Padded vinyl roof C10 Windshield Washer C14 Two speed wipers With washers C24 Special windshield wipers C28 Dual action tailgate C30 Heater/defroster (standard) C48 Heater delete C49 Electro-clear defogger C50 Rear window defogger 1964- C51 Rear window air deflector Station wagon C56 Upper level ventilation C60 Air conditioning 4 season C65 Air conditioning Deluxe C75 Air conditioning Automatic temperature control C80 Front door jam switch D10 Rear arm rest D24 Litter container D31 Inside non glare rear view mirror D33 Remote control mirror D34 Vanity visor mirror D55 Center floor console D64 Illuminated visor mirror D68 Twin remote sport mirrors D80 Auxilary valance panel D85 Body side pin striping D88 SS hood & deck lid stripe 1970-1972 Chevelle D91 Front paint stripe D96 Wide paint stripes 1967- Body side accent stripe D99 Two-tone paint moldings DX1 Front end & hood stripes F40 H.D. front & rear suspension F41 Special performance front & rear suspension F60 Heavy duty front springs F62 Front springs FE8 Radial tuned suspension FR1 Front spring Left side FR2 Front spring Right side G11 2.56 axle ratio G31 Special rear spring G32 Rear springs G33 Rear spring Left side G34 Rear spring Right side G66 Air shocks Rear G67 Controller for air shocks G74 Heavy duty suspension G75 3.70 axle ratio G76 3.36 axle ratio G80 Positraction rear 1963- G81 Positraction G82 4.56 axle ratio G84 4.10 axle ratio G91 3.08 axle ratio G92 3.08 axle ratio G94 3.31 axle ratio G95 2.73 axle ratio G96 3.55 axle ratio G97 2.73 axle ratio GM8 2.56 axle ratio GS1 2.73 axle ratio GS3 3.73 axle ratio GS4 3.70 axle ratio Positraction GS5 4.11 axle ratio GS6 4.56 axle ratio Positraction GT1 2.56 axle ratio GT2 2.29 axle ratio GV1 2.73 axle ratio Positraction GV2 3.08 axle ratio GV3 3.08 axle ratio GV4 3.36 axle ratio GV5 3.55 axle ratio GV7 3.55 axle ratio GV8 4.11 axle ratio GW2 2.56 axle ratio GW3 2.56 axle ratio GW5 2.73 axle ratio GW8 4.10 axle ratio GX1 3.70 axle ratio GX2 3.07 axle ratio GY2 3.31 axle ratio GY2 3.31 axle ratio H01 3.07 axle ratio H05 3.73 axle ratio J50 Power brake J52 Disc brakes Front J56 Heavy duty brakes J61 Disc brake delete J65 Metallic brakes 1964- JL2 Disc brakes Front JL8 Disc brakes Front & rear KO2 Thermomodulated clutch fan KO5 Engine block heater K19 A.I.R. smog pump 1966- K24 Closed ventilation PCV K30 Cruise control K66 Transistor ignition K72 Emission control delete K75 Emission control delete K76 61 amp alternator K77 55 amp alternator K79 42 amp alternator K81 62 amp alternator K85 63 amp alternator K21 Engine controlled combustion system K45 Air cleaner Oil bath type 1 lb. capacity K46 Air cleaner H.D. pre cleaner K47 Air cleaner Oil bath-pre cleaner KD5 H.D. PCV system L08 Engine emission CHI 1972 L14 307 CID V8 1968-73 L22 250 CID 6 cylinder L26 230 CID 140hp 6 cylinder L30 327 CID V8 250hp 4 barrel L31 409 CID V8 400hp 1963-65 Special high performance-solid lifter cam/1-4bbl L33 409 CID V8 340hp 1963-65 Low performance-hydraulic cam/ 1-4bbl L34 396 CID V8 350hp L35 396 CID V8 325hp L36 427 CID V8 L46 350 CID V8 L48 350 CID V8 300hp L61 230 CID 6 cylinder L62 --- CID 6 cylinder High performance L63 --- CID 6 cylinder Special high performance L65 350 CID V8 250hp L66 396 CID V8 265hp 1969- 2 barrel L68 427 CID V8 High performance 3-2 bbls L71 427 CID V8 Special high performance 3-2 bbls L72 427 CID V8 425hp L73 327 CID V8 250hp L73 396 CID V8 Special high performance L74 327 CID V8 300hp L75 327 CID V8 300hp L76 327 CID V8 340hp L77 283 CID V8 220hp 4 barrel carb L78 396 CID V8 375hp L79 327 CID V8 350hp Special high performance L80 409 CID V8 425hp 1963-64 Special high performance-solid lifter/2-4 bbls L74 327 CID V8 360hp fuel injection L85 250 CID L6 4 barrel carb L87 --- CID 6 cylinder Turbo charged L88 427 CID V8 Heavy duty L89 396 CID V8 375hp Aluminun heads L90 250 CID CID 6 cylinder Low compression LF6 400 CID V8 225hp 1970- 2 barrel LF7 327 CID V8 2 barrel LM1 350 CID V8 255hp 1969- 4 barrel LS1 427 CID V8 1969- 4 barrel LS3 400 CID V8 330hp 4 barrel LS3 402 CID V8 300hp 1971 LS3 402 CID V8 240hp 1972 LS4 454 CID V8 235hp 1970- 4 barrel LS5 454 CID V8 360hp 1970 4 barrel LS5 454 CID V8 365hp 1971 4 barrel LS5 454 CID V8 270hp 1972 4 barrel LS6 454 CID V8 450hp 1970 Spec. hi-perf. & 4 bbl LS7 454 CID V8 Heavy duty & 4 barrel LT1 350 CID V8 Special high performance LT4 400 CID V8 180hp M10 Overdrive M11 Floor shift transmission M13 H.D. clutch M20 4 speed standard transmission Muncie M21 4 speed close ratio transmission 1963- Muncie M22 4 speed H.D. transmission Muncie M35 Powerglide 2 spd automatic trans. 1963- M38 Turbo 350 automatic trans. M40 Turbo 400 automatic trans. 1966- M55 Transmission cooler MB1 2-Speed Trans.-Manual Shift MO1 H.D. 11 inch clutch MC1 H.D. 3 spd transmission N03 Gas tank-36 1/2 gallons N10 Dual exhaust N11 Off road service exhaust N14 Side mounted dual exhaust N30 Deluxe steering wheel 1967- N31 Custom steering wheel N32 Steering wheel-wood N33 Tilt steering 1963- N34 Steering wheel-wood grain plastic N36 Telescopic steering column 1966 N37 Tilt steering/telescopic 1966 N40 Power steering N41 Power steering N44 Special steering N61 Dual exhaust-deep tone muffler N65 Space saving spare tire N66 Supersport wheel, hub cap & trim ring N89 Aluminum wheel 15" X 6" N95 Wire wheel covers N96 Simulated magnesium wheel covers NA9 Evaporative emission controls NB2 Exhaust emission NC8 Chambered exhaust system NF2 Dual exhaust-deep tone muffler NK1 Cushioned steering wheel NK2 Deluxe vinyl steering wheel NK4 Sport steering wheel 1971- P01 Wheel trim cover P02 Simulated wire wheels 14 inch P05 Chrome wheel 14 inch 1963 P06 Wheel trim rings P12 14X6 JK wheel P19 Spare tire lock P42 15X6 J wheel P48 15X6 L wheel P48 Cast aluminum knock off wheels Corvette P49 Chrome wheel P58 7.35 X 14 4 py whitewall rayon tubeless P60 7.75 X 14 4 py blackwall nylon tubeless P61 7.75-14 4 ply whitewall nylon P62 7.75 X 14 4 ply whitewall rayon P65 7.75 X 14 4 ply blackwall rayon tubeless P67 6.95-14 whitewall tire P70 7.35 X 14 4 ply blackwall nylon tubeless P75 8.25 X 14 4 ply blackwall rayon tubeless P76 8.25 X 14 4 ply blackwall nylon 1963- P77 8.25 X 14 4 ply whitewall rayon 1963- P90 7.75 X 15 4 ply blackwall rayon Tubeless P91 7.75 X 15 4 ply blackwall nylon Tubeless P92 7.75x15 Whitewall Tires P93 7.75 X 15 4 ply blackwall rayon Tube P95 7.75 X 15 4 ply blackwall nylon Tube P97 7.75 X 15 4 ply blackwall nylon Tube PA2 Simulated magnesium wheel covers PA3 Deluxe wheel covers PE1 Turbine 1 wheels PE3 Turbine 2 wheels PK2 G78-14 White stripe tire PK4 G70-14 Red stripe tire PL3 E78-14 White stripe tire PL4 F70-14 White letter tire PL5 F70-14 White letter tire PM6 G78-14 White stripe tire PM7 F60-15 White letter tire PN5 7.75-14 8 ply tire PQ7 8.25-14 White stripe tire PR3 8.25-14 8 ply White stripe tire PU8 G78-15 White stripe tire PL2 E78-14 Blackwall tire PW7 F70-14 White stripe tire PW8 F70-14 Red stripe tire PX5 F78-14 Blackwall belted tire PX6 F78-14 White stripe tire PX8 G70-14 White stripe tire PX9 G70-14 Dual White stripe tire PY4 F70-14 White stripe tire PY5 F70-14 Red stripe tire PY7 G70-14 Red stripe tire PH1 15X7 wheel Q04 8.15 X 15 4 ply blackwall rayon tubeless Q05 8.15 X 15 4 ply blackwall nylon tubeless QB1 7.75x15 Redline Tires QDR GR78-15 radial whitewall QEH E78-14 bias ply whitewall QEL HR78-15 radial whitewall QGF G70-14 bias ply whitewall QGK G78-14 QGL GR78-14 bias ply whitewall QHE H78-14 bias ply QHF H78-14 bias ply whitewall QQZ HR70-15 radial whitewall QRM GR70-15 radial whitewall QRN GR70-15 radial QRV HR70-15 radial QRZ GR701-15 radial white letter T07 7.75-14 White stripe tire T11 6.95-14 8 ply tire T14 7.75 X 14 8 ply blackwall rayon T15 7.75-14 8 ply tire T18 8.25 X 14 8 ply blackwall nylon T19 8.25 X 14 8 ply whitewall nylon T25 7.75-15 8 ply blackwall rayon tubeless T27 7.75-15 8 ply blackwall rayon tube T58 Rear wheel skirts T60 Heavy duty battery 1963- T74 Left hand rule of road This was for exported cars and had to do with the aiming of headlights for LH driving T78 Front fender running lamp T81 Headlamp light watch/off control T83 Retractable headlamp cover T86 Back up lamps TJ2 Front fender louver U03 Low "D" note horn U05 Dual horn U08 Horn, dual electric 1972 U14 Instrument panel gauges U15 Speed warning indicator 1967- U16 Tachometer U17 Front compartment console instrument cluster U18 Export speedometer U23 Ignition lock light U25 Luggage compartment light U26 Under hood light U27 Glove compartment light U28 Ashtray light U29 Instrument panel courtesy lights U35 Electric clock U46 Lamp monitoring U57 8 track tape player U58 Radio AM/FM U60 Radio-AM-manual tuning U63 Radio AM push button U65 Signal seeking AM radio U69 Radio AM/FM push button 1963- U73 Manual antenna-rear U75 Power antenna-rear U76 Windshield antenna U79 Radio-stereo U80 Auxilary speaker UA1 Heavy duty battery UA6 Horn alarm system UF1 Mirror map light 1969-1972 UF7 Econominder gauge package UM1 Radio AM/tape player 1970- UM2 Radio AM/FM/tape player V01 Heavy duty radiator V02 Heavy duty radiator 1964 VE3 Special front bumper VE5 Deluxe bumper strips VF3 Deluxe front & rear bumper V30 Bumper gaurds-front & rear (set) V31 Front bumper gaurds 1964-1970 V32 Rear bumper gaurds 1964-1970 V54 Roof rack-deluxe-adjustable V55 Carrier, roof luggage V74 Hazard warning equipment 1966 V75 Traction dispenser W81 Bumper face bar taping W89 Touch up paint X14 Export Preperation-coating YC1 Differential carrier 3.08 posi YC2 Differential carrier 3.36 posi YC3 Differential carrier 3.55 posi YC4 Differential carrier 4.11 posi YC6 SS 454 conversion YE7 Special Performance package 1971-1972 This was used on the 71-72 GMC Sprints YF3 Heavy Chevy package Used on Chevelles YF5 Emission tested YF8 Black stripes Z01 Comfort & convience equipment 1963-67 Includes; inside mirror, standard outside mirror, 2 speed wiper/washer, back up lights, glove box light, trunk light, and window washer fluid bottle. Z02 Pushbutton radio & extra speaker 1963- Z03 Supersport package Z04 Heavy duty chassis Z05 Carburetor, economy Z06 SS 396 Z06 Special performance equippment package Corvette Z08 Body molding/trim Z09 Performance rear axle 1970+ Z11 The aluminum nosed 430hp 427 Impala 1963 only Also see: Z-11 fact page Z-11 trivia page Z12 Speedometer driven gear & fitting Z13 Confort & convenience equipment 1967 Same as Z01 except w/remote control mirror Z14 Air conditioning (all weather) body conversion Z15 SS 454 Z16 Special sport coupe Z17 Special suspension/steering Monte Carlo SS Z18 Caprice Custom Sedan 1965 only This was the optional Caprice package that could be added to the Impala 4 door sport sedan. This is the only year the Caprice was an option. Z19 Convenience group Z20 Monte Carlo SS 454 Z21 Exterior moldings 1967- Z22 Rally sport package 1967- Z23 Interior decor package 1967- Z24 SS 427 Z25 SS 396 Z26 Supersport Z27 Supersport Z28 Special engine Z29 Vinyl stripe Z49 Canadian base equipment Z51 Spirit of America packages Included special red, white and blue trim, stripes, and interior-Available on Nova, Impala and Vega Z52 Full foam seat Z53 Amp, oil pressure and temperature gauge Z55 Special VIN plate Z57 Vinyl coated trim Z67 Speedometer driven gear adapter/keys Z83 Road hazzard package 1966 Z87 Deluxe interior Z95 Regular fuel engine equipment ZJ1 Custom exterior ZJ3 Interior convenience package ZJ5 Exterior decor ZJ6 Special sport sedan 1968+ ZJ7 Rally wheels ZJ9 Auxillary lighting group Included; map light mirror, trunk light, underhood light, ashtray light and courtesy lights. ZK1 Body insulation package ZK3 Deluxe seat belts & front shoulder harness 1968+ ZK5 Concours sedan 1968 ZK6 Concours sport coupe 1968 ZK7 Concours sport coupe 1968 ZK8 Tire pressure label 1970 ZR8 Alternate stripe color (SS) ZKQ Tire pressure decal ZL2 Special hood, cowl induction 1970+ ZL3 SS 396 ZP2 Trim & paint color override This was used when a car had an exterior/interior color combination that was not normally used. ZP3 Special paint ZP5 Appearance gaurd group ZQ2 Operating convenience group ZQ7 Canadian warranty booklet & misc. literature ZQ9 Rear axle Performance ratio ZR1 Off road package (LT1) ZR2 Off road package (LS7) ZW4 Standard 3 speed transmission 1970 Link to comment Share on other sites More sharing options...
