BigBlockMonte Posted February 22, 2011 Share Posted February 22, 2011 Hey guys I'm looking at bowties 2004r trans for the chevelle. I found one local to me thats new never installed. It comes with a 2500 converter. My camshaft is a XE284H. Here's the specs: http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=397&sb=2 I know this calls for a 2800+ stall. What I'm asking is can I get away with a little tighter stall and still behave nicely. rest of the set-up is 468 CI 10.25 Compression XE284H Camshaft Eddy Air Gap Intake Aluminum Heads 320cc, 2.25/1.88 valves Holley 850 Carb 3.73 Posi Rear. 28" tall tire I have a TH350 in the car with a 2800-3200 Stall Converter. Will this work? Thanks everyone. Quote Link to comment Share on other sites More sharing options...
Winston Wolf Posted February 22, 2011 Share Posted February 22, 2011 I think it will work just fine. I would run it. Doubt you would even notice the difference between a 2800 and a 2500. You should have plenty of torque. The good, high stall 200-4r converters with heavy duty multi disc clutches run $1000. Quote Link to comment Share on other sites More sharing options...
BigBlockMonte Posted February 22, 2011 Author Share Posted February 22, 2011 Thats what this guy local to me is selling his for. 2004r trans with 2500 converter. Im awaiting the specs on his trans and a copy of the paperwork before I decide. I just needed to know if everything pans out ok. I could run that converter. Thanks so much for replying back. Quote Link to comment Share on other sites More sharing options...
