monte70car Posted February 29, 2012 Share Posted February 29, 2012 Last week I order a new cam and lifter set along with some assemble lube. Does the lifts need to soak in oil a day or so before the install or is it just a matter of lube on the bottom of the lifters? I've seen where people put the cam in a oil bath then put lube journals and others just put lube on the journals just want to make sure I do it right the first time. Quote Link to comment Share on other sites More sharing options...
CrazyDavey Posted February 29, 2012 Share Posted February 29, 2012 Rob this is pretty good.. http://www.cranecams.com/uploads/instructions/214e.pdf Quote Link to comment Share on other sites More sharing options...
monte70car Posted March 1, 2012 Author Share Posted March 1, 2012 Davey thanks for the linky. I started pulling parts off the motor this morning only thing left is to get the motor on top dead center, pull the intake along with the balancer. here are some pictures from the tear down. water pump and fan. got a new timing chain cover coming Quote Link to comment Share on other sites More sharing options...
