green_monte Posted July 19, 2012 Share Posted July 19, 2012 hi look at this link and say what you think of this sound i have run the engine whitout any belts, adjusted the valves and changed the hedder gaskets but nothing helps. the engine is brand new have only about 150 miles on it when the sound started. the sound follows the rpm and is only there when its warm. can it be a lifter problem? the cam is a zz502 roller cam with morel lifters. Quote Link to comment Share on other sites More sharing options...
Murphy Posted July 20, 2012 Share Posted July 20, 2012 A buddy of mine had a similar problem with a new motor and it was a lifter hitting the valve cover and was only noticed after he was cleaning the inside of the cover and saw a wear mark in the metal.........I think he then installed a thicker gasket?? Quote Link to comment Share on other sites More sharing options...
green_monte Posted July 20, 2012 Author Share Posted July 20, 2012 i already have the extra thick gaskets think it is 0,315. if it was the rockers hitting the cover wouldn't it sound loud all the time? when i drive the car so the engine is under load the sound is VERY loud. Quote Link to comment Share on other sites More sharing options...
Murphy Posted July 20, 2012 Share Posted July 20, 2012 As I recall, the ticking sound developed after the engine was warmed up and coincided with the RPM's. He must have adjusted/checked lifters 3 or 4 times before he stumbled on the issue. He had Edelbrock aluminum valve covers. Quote Link to comment Share on other sites More sharing options...
black07ss Posted July 21, 2012 Share Posted July 21, 2012 Do you have a metal inspection cover on the trans? If you do maybe it is hitting the flex plate just a little. Quote Link to comment Share on other sites More sharing options...
