LostnFound Posted October 23, 2012 Share Posted October 23, 2012 I found this carb info on the net. 1971-72 Carburetor Initial Adjustments Adjust with air cleaner installed. The following initial idle adjustments are part of the normal engine tune-up. There should be a tune-up decal placed conspicuously in the engine compartment outlining the specific procedure and settings for each engine application. Follow all of the instructions when adjusting the idle. These tuning procedures are necessary to obtain the delicate balance of variables for the maintenance of both reliable engine performance and efficient exhaust emission control. All engines have limiter caps on the mixture adjusting screws. The idle mixture is preset and the limiter caps installed at the factory in order to meet emission control standards. Do not remove these limiter caps unless all other possible causes of poor idle condition have been thoroughly checked out. The solenoid used on 1971 carburetors is different from the one used on earlier models. The Combination Emission Control System (C.E.C.) solenoid valve regulates distributor vacuum as a function of transmission gear position.The C.E.C solenoid is adjusted only after: 1) replacement of the solenoid, 2) major carburetor overhaul, or 3) after the throttle body is removed or replaced. All initial adjustments described below are made: 1. With the engine warmed up and running. 2. With the choke fully open. 3. With the fuel tank line disconnected from the Evaporative Emission canister on all models. 4. With the vacuum hose disconnected at the distributor and plugged. Be sure to reconnect the distributor vacuum hose and to connect the fuel tank-to-evaporative emission canister line or install the gas cap when idle adjustments are complete. V8-307 & 350 (2-BBL) ENGINES 1. On 1971 models, adjust the carburetor idle speed screw to obtain 600 rpm for manual transmission (in Neutral) with the air conditioning turned off, or 550 rpm for automatic transmissions (in Drive) with the air conditioning turned on. Do not adjust the solenoid screw. On 1972 models, turn the air conditioning off and adjust the idle stop solenoid screw to obtain 900 rpm for manual transmissions (in Neutral) or 600 rpm for automatics (in Drive). Place the transmission in Park or Neutral and adjust the fast idle cam screw to get 1,850 rpm on 307 engines and 2,200 rpm on 350 engines. 2. Reconnect the vapor line and distributor vacuum advance line. V8-350 (4-BBL) ENGINE 1. On 1971 models, adjust the carburetor idle speed screw to obtain 600 rpm for manual transmissions (in Neutral) with the air conditioning turned off, or 550 rpm for automatics (in Drive) with the air conditioning turned on. Do not adjust the solenoid screw. On 1972 models, turn the air conditioning off and adjust the idle stop solenoid screw to get 800 rpm for manual transmissions (in Neutral) or 600 rpm for automatic transmissions (in Drive). 2. For both 1971 and 1972 models, place the fast idle cam follower on the second step of the fast idle cam, turn the air conditioning off and adjust the fast idle to 1,350 rpm for manual transmissions (in Neutral) or 1,500 rpm for automatics (in Park). 3. Reconnect the vapor line and the distributor vacuum advance line on all models. V8-402 & 454 ENGINES 1. On 1971 models, turn off the air conditioner and adjust the carburetor idle speed screw to obtain 600 rpm with manual transmissions in Neutral and automatics in Drive. Do not adjust the solenoid screw. On 1972 cars, turn off the air conditioning and adjust the idle stop solenoid screw to 800 rpm (in Neutral) for manual transmissions and 600 rpm (in Drive) for automatics. 2. On both 1971 and 1972 cars, place the fast idle cam follower on the second stop of the fast idle cam, turn off the air conditioner and adjust the fast idle to 1,350 rpm for manual transmissions (in Neutral) or 1,500 rpm for automatics (in Park). 3. Reconnect the vapor line and the distributor vacuum line on 1971 and 1972 cars. Quote Link to comment Share on other sites More sharing options...
