Oil pump Eco
ClassicJJ
I have a 70 monte with the orginal 350 4bbl set up but back by the 200 4r. The issue I'm having is I'm hearing this clacking noise from the motor it's not very loud at all and the motor still feels fine. My dad seems to think it's an oil pump Eco. Any others ha I g this problem and do I leave it or change the pump? Thanks in advance!!
Are you running the stock oil pump and stock distributor?
You may want to pull out the dist and inspect the gear. Perhaps the timing chain is so loose it's hitting the inside cover?
Good luck,
Bruce
I would pull it and check the gear. Not that big of a deal. Did the noise start after or some time after the HEI or was it there before?
