'72 A/C Clutch connector?
gpbeau
New member and new owner of a restored '72. Went to turn on the A/C and found that the clutch wouldn't close. A quick inspection found that the typical two-wire clutch connector on the compressor housing routes to a connector that is clipped to the vapor lines on the LH fenderwell. This connector has three wires: one to the clutch; one to the temp switch on the "suitcase" on the RH side of the firewall; and a black wire to the back of the compressor. (click the links below to open the two pictures)
a>
a>
My two questions are 1) what does this three-wire connector plug in to? I cannot find any matching connector from any portion of the harness underhood. 2) what in the world is that black wire connected at the back of the compressor for? With the key off, there is no continuity to ground. With the key on, there is no voltage between that wire and ground.
Any help is much appreciated
Welcome to the site and I’m sure you’ll find a lot of help here if things come up.
The connector you’re referring to is where you connect a thermal limiter. Some people refer to it as a fuse. It’s available at most auto parts stores for a few bucks. You’ll just plug it to the connector and let it lay on the inner fender.
The black wire going to the back of the compressor is hooked to the super heat cutout switch. It protects the compressor in high heat situations.
Thanks, Topless72 for the quick response! Curious that the thermal limit switch and the super heat cutout switch don't appear on the wiring diagram. Would be very curious to see a schematic of that cutout switch. Where can a guy get his hands on the limit switch?
Here it is. This is from the 1972 GM issued Service Manual page 1A-60.
Look at the lower left of the drawing.
In the same manual, Pages 1A-53~54 outline the tests and troubleshooting methiods for both the Super heat switch and the thermal limiter.
Perfect! Thanks for that picture. I guess I need to get my hands on the right wiring diagrams.
And thanks to Leghome for letting me know where to get the part. Off to NAPA to get a thermal limiter.
Thanks!
