Guest Posted June 7, 2006 Share Posted June 7, 2006 Just had it rebuilt with transgo kit and new converter 2500 rpm stall (this is behind a pretty stout 454). I have played with the vacuum modulator to no avial. 1) When taking off at normal acceleration 1-2 shift you can't even feel it, seems to be shifting around 1200 or so. 2) When taking off at WOT the 1-2 shift occurs at very high rpms, I ran it up to 5500 and it had not shifted yet so I got out of it then lightly back into it and it shifted. 3) 2-3 shifts seems to be fine in either scenario. 4) No kickdown hooked up.....when crusing about 40-45 mph in 3rd, if I throttle about 3/4 it feels like it down shifts to 2nd, then will shift back to 3rd. Any help would be appreciated. Thanks! Quote Link to comment Share on other sites More sharing options...
Guest Posted June 7, 2006 Share Posted June 7, 2006 Check your vacum lines for leaks and kinks if there is a leak or a kink in the line it will make your trans do some crazy stuff, fluid level??? (not trying to be sarcastic) Quote Link to comment Share on other sites More sharing options...
Guest Posted June 14, 2006 Share Posted June 14, 2006 Ended up putting lighter weights in the governor and now works great. I didn't know it but the guys on the chevelle forum let me know on a TH400 low rpm (easy) throttle shifts are done by the modulator and WOT shifts are done by the governor. Quote Link to comment Share on other sites More sharing options...
Heckeng Posted June 14, 2006 Share Posted June 14, 2006 Drogo99, which chevelle forum were you using? I am looking for some people who have lots of experience with trannys too! Quote Link to comment Share on other sites More sharing options...
502ci Posted June 14, 2006 Share Posted June 14, 2006 Not sure which chevelle forum he`s referring to but it`s probably this one... www.chevelleforum.com This is a pretty good site. Quote Link to comment Share on other sites More sharing options...
Kliegl Posted June 15, 2006 Share Posted June 15, 2006 . Quote Link to comment Share on other sites More sharing options...
Guest Posted June 15, 2006 Share Posted June 15, 2006 Yep thats the site....www.chevelles.com I also own 2 chevelles so I check there often. FYI...I like driving my monte more...it get more attention because people don't know what it is. Quote Link to comment Share on other sites More sharing options...
