420ponies Posted April 30, 2015 Share Posted April 30, 2015 I have just put in the tail lights and have used a variable rate electronic flasher (w/ground wire) to replace my stock one. My question, the lights when turned on tend to flutter when looking at them up close and they flash quick when turn signal is on. Is this normal? I do like them for the 3 quick flashes for the brakes, but wondering what I can do for the flutter when turned on. I am using the regular ground wire from the stock wiring. Should I tape off the steel plates that sit on the tail light fixture? Is it a ground problem? Quote Link to comment Share on other sites More sharing options...
lastss Posted April 30, 2015 Share Posted April 30, 2015 No need to tape off plate, They are what's referred as Rapid Fire bulbs & that's Normal enjoy. Did you install with stock lens gasket?? Quote Link to comment Share on other sites More sharing options...
420ponies Posted May 1, 2015 Author Share Posted May 1, 2015 I did not use my stock gaskets, I used the ones supplied. I was careful to tighten evenly around the tail light lens. I have some new grilles for these from the Parts Place , but they do not fit my stock lenses. I need to see if they have lenses that fit these. Quote Link to comment Share on other sites More sharing options...
