my muncie is chewing up speedometer gears
farmall
Hello monte lovers.  I recently installed a muncie 4 speed in my 72 monte with 350.  I have an 8 tooth drive gear and a 19 tooth driven gear for the speedometer.  According to a calculation using the gear ratio and tire size, I need to have an 18 tooth driven gear with my 8 tooth drive gear.  I bought one, dropped it in and the speedometer was way off, showing 15 miles under the actual speed.  I removed it thinking that I should have counted the teeth before I put it in.  When I removed it, I found that the teeth were messed up.  Figuring that I didn't get the teeth meshed, I threw it out and put the 19 back in until I could get another 18.  I got my second 18 and it did the same thing.  I did take my time, using a number 1 square bit screwdriver while pushing it in to get things lined up.  Is there something I am missing?  Why is this happening.   I am going to attach some pics but they are not the best.  I have tried in many angles with different amounts of light and these are the best.
