DDay Posted September 7, 2015 Share Posted September 7, 2015 I'm thinking of a big block conversion. I have located a1976 454 4bolt complete. Would this be a good start for a build or should I look for an earlier motor. I would like 450 to 500 hp. Thanks, Don Quote Link to comment Share on other sites More sharing options...
dbreese Posted September 7, 2015 Share Posted September 7, 2015 Hey Don, Glad to see ya back!! If the block and crank/rods check out good you got a good base. Some good aluminum heads/intake and a mild hydraulic roller and your goal would easily be obtained with pump gas and have some stump pulling torque. I'm sure the B/B gurus will chime in and give you some choices on parts that will get ya there. David Quote Link to comment Share on other sites More sharing options...
GatorDog72 Posted September 9, 2015 Share Posted September 9, 2015 Do you know what it came out of? Mine was a 73 454 out of a pickup and had open chamber heads and dished pistons. Very low compression. Smog engines of that era were very choked out from the factory. Just bump the compression and get a hyd. roller cam and 500 hp should be easy to make. Quote Link to comment Share on other sites More sharing options...
