Guest Posted May 12, 2001 Share Posted May 12, 2001 Hey everyone. I have a '72 Monte with a 454, and the stock, low style valve covers. I just bought a set of roller rockers and i was wondering if i will need a taller valve cover? Additionally, with a taller valve cover, on the driver side, the valve cover will hit the vacuum booster. Has anyone else had this problem? If so what valve cover did you go with? Thanks Link to comment Share on other sites More sharing options...
monte70car Posted May 12, 2001 Share Posted May 12, 2001 i have a set of tall vale covers on my 402 and i dont have a problem with the brake boster. ------------------ robert drive it like u dont own it. Link to comment Share on other sites More sharing options...
Guest Posted May 13, 2001 Share Posted May 13, 2001 I have stock covers on my 468 with roller rockers. I used two rubber gaskets under each side. I used 3M trim adhesive and glued the gaskets together so they wouldnt slide around. They have never leaked and you cant tell they are there. Link to comment Share on other sites More sharing options...
MeanMonte Posted May 13, 2001 Share Posted May 13, 2001 I done the same for my roller rockers on my SB i used two rubber gaskets under each cover and glued them togeather with guess what.........3m glue hahahhah ohh yeah and it works with no leaks also Link to comment Share on other sites More sharing options...
