amsterdam84 Posted July 20, 2016 Share Posted July 20, 2016 I like this thread. Been looking at the Viking coil over setup for some time. Can anyone comment on the rise quality after upgrading? Quote Link to comment Share on other sites More sharing options...
Rock Posted July 20, 2016 Author Share Posted July 20, 2016 The fronts I would say you have about 2-3" of adjustability and the rears have well over 4". With just a few clicks you can go from a Cadillac to a Porsche in ride quality. What more could one want? Quote Link to comment Share on other sites More sharing options...
amsterdam84 Posted July 21, 2016 Share Posted July 21, 2016 Glen, that would be using the adjustment for rebound and compression? Quote Link to comment Share on other sites More sharing options...
Rock Posted July 21, 2016 Author Share Posted July 21, 2016 The shocks come with 2 clicker knobs, one for compression and one for rebound. They have 12 different settings each. The spring position determines ride height. It is adjustable using spanner wrenches that are included. The rear shock position has an upper or lower position to help with the ride height you want. I chose the upper position and my rear is around 26" from the ground to the center of the wheel well. If you choose you can have a low rider and use the lower shock mount. Hope this helps. Quote Link to comment Share on other sites More sharing options...
amsterdam84 Posted July 21, 2016 Share Posted July 21, 2016 Yes it does. Been looking at that kit for 2 years now. Sadly the American dollar going up did not help. To my door it will probably cost me about 2k for front and rear. Hard pill to swallow. I need a new front suspension though as mine is the original and it's sagging so bad I scrub my fenders when I turn. Â That and I have a 454 waiting it's turn in the engine bay. Quote Link to comment Share on other sites More sharing options...
Rock Posted July 21, 2016 Author Share Posted July 21, 2016 Yeah, lot of money for the kit but if you can take the hit, it is a good upgrade all around. On a side note all of the annoying noises that come from the original springs are now gone and it rides so much better. I also changed out the lower rear control arms too. Quote Link to comment Share on other sites More sharing options...
amsterdam84 Posted July 22, 2016 Share Posted July 22, 2016 Go adjustable? I have a few things that will be done at the same time. Have boxed lowers to go with a sway bar and hopefully I can get the 12 bolt rear out of the parts car and throw that in. Quote Link to comment Share on other sites More sharing options...
