snomobeelr Posted July 30, 2016 Share Posted July 30, 2016 Car has been running great other than having to change the Battery. We were leaving to go to a car cruise/show and I pull out and going down the street she is backfiring/popping through the exhaust. Not horrible but enough. I pull over to the side of the road and place it in park . I rev it up and its fine , no popping through the exhaust. Start down the road and its popping. Drove home into garage. Checked Timing its fine. Checked plug wires connected - fine. Fuel pressure a 7 lbs and see fuel in bowls. AArrggg Quote Link to comment Share on other sites More sharing options...
dejh22 Posted August 16, 2016 Share Posted August 16, 2016 Do you have HEI or a points distributor? If it is a points distributor could be the dwell needs to be adjusted? Quote Link to comment Share on other sites More sharing options...
