earle54 Posted September 19, 2016 Share Posted September 19, 2016 OK, have a 71 with stock 2.73-non-posi I believe. Want to upgrade to 3.42 or maybe 3.55. Upgraded with top end-kit & now want to turn it up a notch with the gear change. Nothing crazy just want a good balance for street/highway cruising, without a huge budget. Local transmission joint says it does this type of work. So,is it simply a matter of changing the carrier from a 2 - 3 series along with the gears themselves ,or is there more to it than that ? All advice is much appreciated ! 1 Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted September 19, 2016 Share Posted September 19, 2016 if you want a positraction, a new carrier would be needed for what you are looking to do...a 3.31 gear is a great choice, but not the easiest ratio to find if you can't find a 3.31, then I would opt for the 3.42 unless you are planning on using an overdrive transmission then I would opt for a 3.55 or 3.73 Quote Link to comment Share on other sites More sharing options...
earle54 Posted September 19, 2016 Author Share Posted September 19, 2016 So, I don't even have to change the carrier if I'm not going with posi ? Any brand suggestions ? Maybe Yukon ? Thanks Sam, I think I'll go will go with the 3.42. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted September 19, 2016 Share Posted September 19, 2016 you may still need to change the carrrier Quote Link to comment Share on other sites More sharing options...
bigscaht Posted September 28, 2016 Share Posted September 28, 2016 you will need to change the carrier for sure...thats what makes the posi is the carrier...i have an eaton tru trac wih 342s... Quote Link to comment Share on other sites More sharing options...
