Guest Posted May 5, 2004 Share Posted May 5, 2004 My transmission mount is obviously the original. It is flat as a pancake. What is the easiest way to replace the mount? Can I just jack up the tranny and remove the old mount or do I have to disconnect the drive shaft and loosen the engine bolts? Quote Link to comment Share on other sites More sharing options...
wallaby Posted May 6, 2004 Share Posted May 6, 2004 Nah, they are just about as simple as hey look. No fancy gymnastics or anything. Quote Link to comment Share on other sites More sharing options...
monzaz Posted June 21, 2004 Share Posted June 21, 2004 just remove the bolts jack the tranny up with a floor jack or bottle jack (put a 2x4 or something between the pan and the jack so you dont ruin the tranny pan. ) then remove the old mount and slide in the new one and bolt in and let jack down holding the tranny up. Worse case you might have to loosen the crossmember if you can not get the tranny up enough in the tunnel. good luck, Jim Quote Link to comment Share on other sites More sharing options...
Guest Posted June 26, 2004 Share Posted June 26, 2004 Thanks for the detailed reply Jim. I haven't tackled this project yet and I'm glad I waited. I never would have thought to put the wood between the tranny and jack. Quote Link to comment Share on other sites More sharing options...
