Guest Posted October 4, 2005 Share Posted October 4, 2005 My car was originally a column shifter. The previous owner then put in a new TH350 with a B and M Floor shifter. Although, he didn't connect the reverse lights to them. So when I put it in reverse the lights won't come on. I have to turn the column where the original shift lever was until the lights come on. I don't really want to just hook up a switch to turn them on and off, so is there a way to make the floor shifter turn on the lights when put in reverse? Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted October 4, 2005 Share Posted October 4, 2005 most shifter manufactures have a switch available for there shifter to hook-up back-up lights and neutal safty switches. hope this helps Sam Quote Link to comment Share on other sites More sharing options...
Guest Posted October 4, 2005 Share Posted October 4, 2005 Is a neutral safety switch the same as a neutral lock out? Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted October 4, 2005 Share Posted October 4, 2005 NO,saftey switch only allows the car to be started in park or neutral, lockout prevents you from hitting neutral when shifting Sam Quote Link to comment Share on other sites More sharing options...
72 LS5 Posted October 7, 2005 Share Posted October 7, 2005 You may be interested in this topic: http://www.firstgenmc.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=6;t=002725 Quote Link to comment Share on other sites More sharing options...
