madmonte Posted July 5, 2005 Share Posted July 5, 2005 how many different yokes did gm make for the 400 turbo? the 400 yoke that i have is 1 7/8 inch diameter,32 spline with 1 large spline,the problem is that it wont even fit into the bushing in the tail housing.way to big. even if the bushing wasnt installed,the yoke would not fit.not sure what year the trans is ,but im sure its a 400 turbo, any help appreciated , ED ( the new drive train is almost complete,468,400 turbo,12 bolt 4:11 posi.) Quote Link to comment Share on other sites More sharing options...
Hoodicoff1 Posted July 7, 2005 Share Posted July 7, 2005 I am in the same boat as you, converting from A TH350 to a turbo 400, I actually found a u-joint at the parts store that has the bigger end caps on one side and the smaller end caps on the other side,workedlike a hotdamn Quote Link to comment Share on other sites More sharing options...
Guest Posted July 27, 2005 Share Posted July 27, 2005 could you have a turbo 375? I think thats basically a turbo 400 with a turbo 350 tail housing, try a turbo 350 yoke, it might fit, Jim Quote Link to comment Share on other sites More sharing options...
