Guest Posted September 18, 2004 Share Posted September 18, 2004 Which manual tranny is the eisiest and best to swap from a auto to manual Quote Link to comment Share on other sites More sharing options...
Andreas Posted September 20, 2004 Share Posted September 20, 2004 Could you tell us what you want to do with your car? Drag Racing? Street? Size of Engine? HP, Torque? Transmission installed now, 350, 400? Do you want overdrive? Rear Gear Ratio? Do you have column shift or floor shift? Console? Do you want to stay all original or is modified ok with you? Quote Link to comment Share on other sites More sharing options...
Guest Posted September 20, 2004 Share Posted September 20, 2004 Just looking for a fast street car Engine will be a 350 with about 425 hp and 440 tq it had a 350 auto it was floor shift no console and modifing is ok i just want a manual that will last i was thinking a saginaw or t5 but need help deciding thanks Quote Link to comment Share on other sites More sharing options...
Andreas Posted September 20, 2004 Share Posted September 20, 2004 The T-5 manuals were build for much lighter cars will not last very long behind your 425 Hp small block in your 4,000 lbs Monte I do not know a lot about the Saginaw, but I have heard bad things about it... What you probably need for that kind of horsepower is a Muncie, Richmond or TREMEC with the Muncie & Richmond being the easiest swap for an auto tranny... Quote Link to comment Share on other sites More sharing options...
Guest Posted September 21, 2004 Share Posted September 21, 2004 I agree with Andreas. No T-5. If you want a 6 speed, you want a T-56 from D&D Performance. 10 times stronger, but get your wallet out. The Tremec TKO is a bit cheaper. The Muncie you could probably get even cheaper. Depends on what gear you plan to run, and how much highway driving you will be doing. The first thing you need to decide is do you need an overdrive. Big J Quote Link to comment Share on other sites More sharing options...
Guest Posted September 23, 2004 Share Posted September 23, 2004 See new car craft. Article about putting Tremec in older cars. I have not yet had a chance to read it. Big J Quote Link to comment Share on other sites More sharing options...
kc8oye Posted October 21, 2004 Share Posted October 21, 2004 Chevy hi performance IT hink it was has an article on a company that sells modified Viper T56's for use in 'standard' sbc applications... I'm interested in doing the same, but I must have an O.D since I expect to use my monte as my only form of transport very soon. Quote Link to comment Share on other sites More sharing options...
Andreas Posted October 22, 2004 Share Posted October 22, 2004 Check out the manual OD tranny kits from http://www.keislerauto.com/home.html Quote Link to comment Share on other sites More sharing options...
