cbolt Posted June 4, 2008 Share Posted June 4, 2008 Does anyone know where I can find the link between the cowl actuator and the actual door for my vacuum pod? In the assembly manual it is part number 7, "link" and mine is broken in half with the half that goes to the cowl fresh air door missing. Should I just take it to an A/C place or try to find this part? Anyone else run into this problem? Thanks in advance. Link to comment Share on other sites More sharing options...
dbreese Posted June 4, 2008 Share Posted June 4, 2008 Cbolt, Give Leo a call 810-329-6868 he may have the part ya need. Good luck. David Link to comment Share on other sites More sharing options...
Big Jim Posted June 5, 2008 Share Posted June 5, 2008 I got mine at National Parts Depot. The same as the Chevelle. It's in the catalog.Part # C-9786-105A $38.95 Air Door complete with hinge. Link to comment Share on other sites More sharing options...
cbolt Posted June 5, 2008 Author Share Posted June 5, 2008 I got mine at National Parts Depot. The same as the Chevelle. It's in the catalog.Part # C-9786-105A $38.95 Air Door complete with hinge. The catalog advertises this as the door for under the dash, not in the cowl. Are they interchangeable? Also, the part that is broken is not a part of the door so much as bolted to the vacuum pod. I am scratching my head over here. Link to comment Share on other sites More sharing options...
dbreese Posted June 5, 2008 Share Posted June 5, 2008 cbolt, I'll get you the GM part # tonight. Again I would check with Leo. David Link to comment Share on other sites More sharing options...
cbolt Posted June 5, 2008 Author Share Posted June 5, 2008 David, I left a message on Leo's answering machine, waiting for a return call. Thanks for the help. Jim Link to comment Share on other sites More sharing options...
