Guest Posted June 13, 2005 Share Posted June 13, 2005 I have a 71 Monte with a 350 and a 350th trans. I was wondering if it would be worth my trouble to swap it out for a 700r4 trans. i'm looking to put a little more power behind the car, and put in 3.55 gears. If anyone can help it would be greatly appreciated Quote Link to comment Share on other sites More sharing options...
Guest Posted June 14, 2005 Share Posted June 14, 2005 Hey, welcome to the site. I have a buddy with the same set up(the 350 is probably pushing around 400 HP) in a 79 camaro and he swapped in a 700-r4 with 3.90 gears. Simply put, the car is an animal now and cruises fine on the highway. He took out a Subaru WRX from a dead stop, despite the all wheel drive!(not that I condone that sort of thing..heh..heh) Just as a heads up, I think the part that surprised him was the converter cost him $750. He used a 10 inch for the higher stall and said it had to be made. Just as a possible alternative, I have a gear vendors overdrive unit in my 70 monte. So far, I think it is great. Quote Link to comment Share on other sites More sharing options...
Guest Posted June 14, 2005 Share Posted June 14, 2005 Oops..My friend swapped in a built 200-r4, not a 700-r4. Sorry. It is supposedly and easier swap as you don't have to cut the driveshaft. Quote Link to comment Share on other sites More sharing options...
Guest Posted June 14, 2005 Share Posted June 14, 2005 Thats awsome! I had my doors blown of by a subaru WRX when I first bought my car. I was embaressing until I found out what their pushing. then I didn't feel so bad. But thanks for the reply. I might put a bigger rear in if I can get away with it then. Quote Link to comment Share on other sites More sharing options...
Dans '70 Z20 Posted August 5, 2005 Share Posted August 5, 2005 Check out these guys. All the racers street and track use 'em on Long Island. http://www.fbperformance.com Quote Link to comment Share on other sites More sharing options...
