TheBMan Posted August 22, 2023 Share Posted August 22, 2023 I replaced this 3-row reproduction radiator with a 4-row so I no longer need this one. It's 4 months old with very few miles on it. Originally purchased from Summit racing, details can be found here: https://www.summitracing.com/parts/SUM-382024 It was a direct bolt-in on my 1970 Monte Carlow with a small block and automatic transmission. Will it fit your car? Check here: https://www.summitracing.com/parts/SUM-382024/applications Nothing wrong with it, near perfect condition. It is currently $390 new on the Summit Racing website. Selling for $275 including shipping within the continental U.S. Private message me if you're interested. (The white spot in the middle of the pictures is light, it's not a blemish.) 1 Quote Link to comment Share on other sites More sharing options...
riverdogs00 Posted August 23, 2023 Share Posted August 23, 2023 Good morning, Did you experience any overheating with the 3 row? I currently have a similar, albeit older radiator in my car and am unsure if it will be enough for a 454 in the desert heat. Quote Link to comment Share on other sites More sharing options...
TheBMan Posted August 23, 2023 Author Share Posted August 23, 2023 12 minutes ago, riverdogs00 said: Good morning, Did you experience any overheating with the 3 row? I currently have a similar, albeit older radiator in my car and am unsure if it will be enough for a 454 in the desert heat. Overheating? Technically, no. Temperature very slowly creeped up at idle. Once moving, temp came back down. I think this radiator is a direct replacement/bolt-in for your big block car but I wouldn't say for sure that it (or any) radiator would be enough in desert heat. If you're looking for a fresh, new, clean radiator, this would be a good choice. 1 Quote Link to comment Share on other sites More sharing options...
