Mike Brichta Posted October 24, 2004 Share Posted October 24, 2004 Hi Guys, I don't know much about a th350 trans, but I think mine is going bad? What do you think? 1) Car seems to have lost some power on the pull. 2) Trans takes a long time between gears. 3) Trans fluid is full. 4) Trans downshifts more often then before. 5) When in reverse, car chatters, like slipping. If it is the trans, should I rebuild or buy new? If I rebuild, I have two trans's out of two different 1970 montes. One was a 265 HP engine, the other a 300 HP engine. Are the trans's the same or are they differnt? Which would be better to use for the rebuild? If I buy new, any suggestions on a good one? Either way, should I also replace the torgue converter, since it is the original one? Thanks!!!! Mike Quote Link to comment Share on other sites More sharing options...
Reaper Posted October 24, 2004 Share Posted October 24, 2004 Sounds to me like the tranny is bad... as far as the tranny's you got out of other Montes there shouldnt be any difference unless one would be a TH400 or different tail shafts for some reason.. Torque converter would I think be up to you... I would replace it if you have another with the other tranny's though... These guys will prolly be able to help you out better but I tried Good luck, Tom Quote Link to comment Share on other sites More sharing options...
