ejw71 Posted June 3, 2004 Share Posted June 3, 2004 Was told that TH350/400s can be rebuilt in home garage. If you have experience doing engines then TH350/400s can be done and only requires simple hand tools. Any advice as I attempt my first TH350 rebuild? Thanks, Ed Quote Link to comment Share on other sites More sharing options...
Guest Posted June 5, 2004 Share Posted June 5, 2004 Number one tip: buy the Turbo Hydra-matic 350 book by Ron Sessions, put out by HPBooks and study it like a Bible. You'll understand the theory and it gives step by step teardown procedures for that particular tranny. Book does not cover the TH400, but it would get you a lot closer in the right direction than a general transmission manual. Will Quote Link to comment Share on other sites More sharing options...
ejw71 Posted June 5, 2004 Author Share Posted June 5, 2004 Thanks Will. Have that book. Have read it and will do again. Is the main difficulty in hobby mechanics from doing GM overdrives, 700R4/2004R, is the lack of the special tools required? Ed Quote Link to comment Share on other sites More sharing options...
Guest Posted June 5, 2004 Share Posted June 5, 2004 theres a special clamp needed for taking out the lower reverse drum i think its like 50 bucks for it. Quote Link to comment Share on other sites More sharing options...
72MC Posted June 6, 2004 Share Posted June 6, 2004 ejw71, it is good to see that someone is on the same page as me. Have the book and with the 355 engine in the works, felt like there is no reason I cant do the tranny as well. Have some friends that have some experience as well so I guess that helps. I bought the Hughes Performance rebuild kit based on "word of mouth" quality over the B&M rebuild kit. I won't be starting the rebuild til probably mid July. Keep me posted of your efforts and hopeful I can return the favor. - Dave Quote Link to comment Share on other sites More sharing options...
ejw71 Posted June 6, 2004 Author Share Posted June 6, 2004 Dave, I also will do rebuild around July/August. Will check with you on progress and if problems arise. Ed Quote Link to comment Share on other sites More sharing options...
