Dorknozzle Posted April 23 Share Posted April 23 What's up guys. I have a 70 small block monte that has been running great for years, but had nasty trans pan and oil pan leaks. I finally got around to changing both pan gaskets. While under there I shimmed the starter because it was screeching, re routed the trans cooler lines that someone before me did a terrible job of, and ran a new 4 gauge starter wire to battery post. Never touched ignition or even took the air cleaner off. After topping of the new oils, the car was hard to start and now will not idle. I can pump the gas and keep it running and the response is pretty good, but as soon as I let off the pedal she dies instantly. What the heck? So now I have removed the air cleaner and if I keep it running long enough for me to reach the carb, I can get it to idle up if I cover the carb with my hand. This leads me think i have a vacuum leak all of a sudden, but I can't find it. What do you guys think? Quote Link to comment Share on other sites More sharing options...
Dtret Posted April 24 Share Posted April 24 Look at the vac line going to the transmission modulator. You may have pulled it off when redoing the lines. 7 Quote Link to comment Share on other sites More sharing options...
