Kevin Wiles Posted April 17, 2009 Share Posted April 17, 2009 my 70 350 auto/air car has a wire that goes along the drivers side inner fender. The wire is green and it is in a fabric-type sleeve. the sleeve is quite sloppy looking and is deteriated. Is there a source for this fabric wire sleeve? Also my throttle cable, where it clips into the bracket on the q-jet, that rubber piece. Where can I get one of those? Mine is cracked and falling apart Link to comment Share on other sites More sharing options...
Kevin Wiles Posted April 17, 2009 Author Share Posted April 17, 2009 i found the cloth wire sleeve on paddock Link to comment Share on other sites More sharing options...
wallaby Posted April 18, 2009 Share Posted April 18, 2009 Kevin, do you mean the grommet that acts as the connection/ isolator between the throttle cable & cable bracket? I thought that piece was a integral part of the cable outer housing. I figured that the only way to replace it was to get a new cable assembly? I've never looked at it too closely....there must be a means of keeping it from sliding up or down on the cable... Link to comment Share on other sites More sharing options...
