DavidTX Posted May 31, 2009 Share Posted May 31, 2009 I have a 700R-4 in my 71. I do have the correct adapter on the carb for the TV cable. I seem to have the cable adjusted properly, good hard shifts with WOT and not too hard with normal acceleration. My problem is that it shifts at about 4,200 to 4,400 rpm at WOT. My engine is dyno'ed at 421 HP at 5,800 RPM and I am not able to take advantage of the available power. How can I get it to shift at higher RPM's?. Quote Link to comment Share on other sites More sharing options...
footballubet Posted May 31, 2009 Share Posted May 31, 2009 You can change the springs in the governor. That will change your shift points. Quote Link to comment Share on other sites More sharing options...
