snomobeelr Posted August 1, 2009 Share Posted August 1, 2009 I have the body off the frame and I am going to do new brake line and mabye fuel line. Do I acually need the Vapor line? Why do I have so many tubes to the Tank? Link to comment Share on other sites More sharing options...
snomobeelr Posted August 2, 2009 Author Share Posted August 2, 2009 Actually I have a 71 . Three who know's what lines, 1 Vapor line and the Fuel. Is it me or is it a bit much? The car is definatly not gonna be an exact resto at all. And I will be staying with a Mechanical Fuel Pump no fuel Injection. But do I need to replace the vapor line? It wasnt going to anything the canister had been removed. Link to comment Share on other sites More sharing options...
footballubet Posted August 2, 2009 Share Posted August 2, 2009 You can remove the vapor line as many here have. I removed all the other lines at the tank to the canister behind the rear seat as well. Then just cap off the lines at the tank. The only thing that you will need to replace is the gas cap. Get a 70 vented cap and you will be good to go. While you have the body off, replace the brake lines also. I used the stainless steel lines on both my fuel and brake lines. Link to comment Share on other sites More sharing options...
