Chevyss Posted August 3, 2009 Share Posted August 3, 2009 What would be the best transmission to put behind a 502/502hp?? If the current trans doesn't work out. I've only put 700 miles on this one and it seems to be slipping when shifting into 2nd. Will know tomorrow. Quote Link to comment Share on other sites More sharing options...
502ci Posted August 3, 2009 Share Posted August 3, 2009 I see you have a 700R4 so I would assume you want an overdrive still. A well built TH400 with a gearvendors under/overdrive unit is as tough as you can get...that's what I have on my car. Quote Link to comment Share on other sites More sharing options...
Chevyss Posted August 3, 2009 Author Share Posted August 3, 2009 Again, Thanks Bill. I will know tomorrow if I need to start looking for another trans. I like the overdrive with the 700R4 when on the road, but I'm not sure if it's the trans, or maybe the BM lockup control is working right. It goes in tomorrow for the fuel system change and while it's there we will see what my trans tech thinks. Will keep you posted Quote Link to comment Share on other sites More sharing options...
Crow Posted August 5, 2009 Share Posted August 5, 2009 I see you have a 700R4 so I would assume you want an overdrive still. A well built TH400 with a gearvendors under/overdrive unit is as tough as you can get... Thats what I would do if I had the money. Quote Link to comment Share on other sites More sharing options...
CrazyDavey Posted August 5, 2009 Share Posted August 5, 2009 Originally Posted By: 502ci I see you have a 700R4 so I would assume you want an overdrive still. A well built TH400 with a gearvendors under/overdrive unit is as tough as you can get... Thats what I would do if I had the money. Royce if it's an around town/track car with little highway then a built 400 (simple and strong). We have 3:73's with a 28" tire and it's still comfortable for an occasional trip on I-5....the overdrive is up to you but I personally don't think you need it ..... Quote Link to comment Share on other sites More sharing options...
