Monte72Carlo Posted December 4, 2009 Share Posted December 4, 2009 To silicone or not to silicone differential gastket. It's a Felpro and I believe it's cork. Thanks, Garrett. Quote Link to comment Share on other sites More sharing options...
Chevyss Posted December 4, 2009 Share Posted December 4, 2009 I'd silicone it to the cover only. Quote Link to comment Share on other sites More sharing options...
Monte72Carlo Posted December 4, 2009 Author Share Posted December 4, 2009 The reason I'm asking is because I don't have any automotive silicone, but have house hold stuff but would rather not. I have permatex gasket maker, would that work? Garrett. Quote Link to comment Share on other sites More sharing options...
Chevyss Posted December 4, 2009 Share Posted December 4, 2009 Only problem with permatex, it's a bi!@h to get off later on. Silcone is much easier. JMO .02 Quote Link to comment Share on other sites More sharing options...
Monte72Carlo Posted December 4, 2009 Author Share Posted December 4, 2009 Can I just use household clear silicone? Garrett. Quote Link to comment Share on other sites More sharing options...
bobsmc Posted December 4, 2009 Share Posted December 4, 2009 i would not use household silicone just glue the gasket to the cover with weatherstrip adhesive and bolt it up. bob Quote Link to comment Share on other sites More sharing options...
allchevy Posted December 4, 2009 Share Posted December 4, 2009 shouldn't need anything. Just bolt it up. Quote Link to comment Share on other sites More sharing options...
wallaby Posted December 4, 2009 Share Posted December 4, 2009 Like valve covers or oil pan, just make sure the tin is flat (no bulges or deformation under the bolts)...in fact it would be better if the bolt holes bulged outward a tiny bit. If the cover is flat, your gasket shouldn't need anything else. Household silicone isn't suitable...it isn't formulated to withstand temperatures or oil. Quote Link to comment Share on other sites More sharing options...
Monte72Carlo Posted December 4, 2009 Author Share Posted December 4, 2009 Sounds good,I will to that today. Thanks, Garrett. Quote Link to comment Share on other sites More sharing options...
