ChrisM Posted May 17, 2010 Share Posted May 17, 2010 hey guys, My names chris, an i have a 1970 monte carlo with a 350 small block an a TH400 backing it up. My question is with the kick down linkage. from the day i bought the car, the kickdown linkage has never connectid. With installing the TH400, i still cannot connect it. It seems like the cable is to short, i have the one bracket at the back of the intake, but it doesnt reach to the carb and there isnt even a spot on the carb to put it. its a reg. holly 600CFM, any ideas or where i can get an adptor to make it fit right? thanks chris Quote Link to comment Share on other sites More sharing options...
Packratt Posted May 17, 2010 Share Posted May 17, 2010 The TH 400 should have a switch on the carb that is tripped when you nail the throttle. A wire harness runs from that switch to a plug on the side of the transmission and that kicks the tranny into a lower gear. If you can post picks maybe someone can help figure out your problem. Good Luck! Quote Link to comment Share on other sites More sharing options...
monte70car Posted May 17, 2010 Share Posted May 17, 2010 Randy the 70-72 GM cars moved the switched to above the throttle pedal. Chris double check your trans again if you have a cable coming up from the passager side you have a 350, 350c(lockup 350) 200r4, 700r4(those are over drive trans which uses a tv cable) 400's used a elec. kickdown which is mounted on the throttle pedal inside the car and has a wire harness. Quote Link to comment Share on other sites More sharing options...
Packratt Posted May 18, 2010 Share Posted May 18, 2010 You are right again Ert. the only one I ever fooled with was behind the carb. Quote Link to comment Share on other sites More sharing options...
