72Monte_Timmy Posted July 20, 2010 Share Posted July 20, 2010 Hey all! My new kickdown cable does not return to it's original position when pulled out. Is it supposed to??? Anybody have a pic of how the kickdown cable rod should be hooked up inside the 350 Turbo Transmission. From the trans end of the kickdown cable (inside pan) I have the little jagged rod/wire attached to a teetering piece that pushes against a "piston/valve" there are no springs on here to return the cable.... should there be??? Quote Link to comment Share on other sites More sharing options...
kc8oye Posted July 21, 2010 Share Posted July 21, 2010 yes, you are missing something. the kickdown valve should pull the cable back with it. it's been so long since I've been inside an TH350 tho..... Quote Link to comment Share on other sites More sharing options...
