72 LS5 Posted May 31, 2011 Share Posted May 31, 2011 I know this topic has been touched on before. But specifically on a high compression Big Block, is anybody running vacuum advance? I always ran it on 454, but it only was a 9 to 1 motor. That extra advance really gave it responsive part-throttle acceleration. With the 10.6 to 1 502, I'm not sure if there will be harmful detonation that may not be detectable. All my mechanical advance is in by 2800 rpms. Chevy recommends no vacuum advance on this motor - so that probably answers my question. Just curious what others are doing. Was there vacuum advance on the old 11 to 1 solid lifer 427s and 454s of the late 60's early 70s? Quote Link to comment Share on other sites More sharing options...
Winston Wolf Posted June 1, 2011 Share Posted June 1, 2011 I'd hardly call 10.6:1 "high compression". I would run it. Just keep it to 10 degrees and have it come off at a higher vacuum if your worried about it. Lot's of places have 93 octane, another thing to help you sleep at night. Quote Link to comment Share on other sites More sharing options...
Mike 57 Posted June 1, 2011 Share Posted June 1, 2011 Yes I would run it also, get an adjustable advance can so you can limit the advance if you run into ping. I run one on mine for cruising, and I am at 11.4 to 1. Quote Link to comment Share on other sites More sharing options...
72 LS5 Posted June 1, 2011 Author Share Posted June 1, 2011 Thanks for the input, I think I'll give it a shot. Quote Link to comment Share on other sites More sharing options...
