Power brake rod
cpmman
How long should the power brake rod (the one that actuates the master cylinder) be in a 70 Monte Carlo?
I do not have any play in the brake pedal with the car off. Brakes seem a bit tight when rolling as well.
No answers yet..but a seasoned mechanic just told me to trim the rod 1/8-1/4" at a time until there is anout 1/2" of play in the pedal with the car is turned off.
What has changed (or was repaired or replaced)? Did it always do this or did you replace the M/C or booster and now it acts this way? Do you have the old M/C to compair? I repaired a car one time where the cross shaft was so badly worn out the clutch and brake peddle were way out of whack. I believe you have a 4 speed with a clutch peddle so you may want to check the entire cross shaft bushing area before grinding away metal you may need.
Bruce
Booster and M/C replaced..the rod with the new MC was to long so the brakes would not bleed. After some trimming of the rod, the brakes bled but now the front brakes are a bit tight and the pedal has no play. I presume a bit more timming will fix it but was wondering if there is a stock length.
Clutch pedal is fine.
