Guest Posted January 4, 2007 Share Posted January 4, 2007 Hello all, I want to put a T56 6 speed transmission in my monte. Has any one out there ever done this? I Know I will have to cut my tunnel and shorten my drive shaft then mount the hydrolic clutch system. I think I can use the stock cross member with a new tranny mount. If anyone knows of anything else that would help me just let me know. I also have a post for instaling an LT1 in the Engine message board. Quote Link to comment Share on other sites More sharing options...
Andreas Posted January 4, 2007 Share Posted January 4, 2007 I know www.keislerauto.com has 5-speed kits for A-bodies and also has T56's for other muscle cars... Install Instructions I have swapped a TREMEC TKO in place of a TH350 (before Keisler existed). No mods to the tranny tunnel (excpet for cutting the shifter hole). I have heard the T56 will require more mods to the tunnel. Had to make an adapter to use the stock tranny crossmember... Have a mechanical clutch... I had a custom driveshaft made at www.dennysdriveshaft.com Quote Link to comment Share on other sites More sharing options...
Guest Posted January 6, 2007 Share Posted January 6, 2007 Thanks Andreas, I will check this sight out, if I cant find any other information I guess I will let you all know how I did it. Quote Link to comment Share on other sites More sharing options...
Donny vestal Posted January 14, 2007 Share Posted January 14, 2007 that will be a fun one to drive Quote Link to comment Share on other sites More sharing options...
Guest Posted January 14, 2007 Share Posted January 14, 2007 Yeah Donny, It will also have an LT1 as soon as I can find the money and time to make it all fit. I pulled the motor and tranny out of the 94 Z28 Camaro yesterday. Quote Link to comment Share on other sites More sharing options...
