bgl0b6 Posted March 22, 2012 Share Posted March 22, 2012 I have asked this question in another part of the forums,hoping some one has the answer.Here is my problem.The car was a 350 turbo,changed to a 400 long shaft from an Impala.both cars were column shift.I drove the Impala before the change and all worked well.If I shift the trans manually from below it shifts into each gear,when I install the linkage and bell crank,it clicks from park to reverse solidly,but to neutral it just fall loosely,then into drive it clicks,2nd solidly and that is as far as it will shift,cannot pull it into low,it just wont go any farther.Is there a difference it the shift rod between a 350 and a 400?I have a parts car that was a 350 trans also,tried the whole set up from that car with the same results,I'm baffled Thanks....Mike I have tried to adjust it from both park position and from low position and get the same results. Quote Link to comment Share on other sites More sharing options...
monte70car Posted March 22, 2012 Share Posted March 22, 2012 The rods coming off the column needs to be adjusted. Without looking at the rods I could not tell you and I'm current at work so I have no access to the el camino that had a 350trans in it and now a 400. Once I get in I will check the the rods Quote Link to comment Share on other sites More sharing options...
bgl0b6 Posted March 22, 2012 Author Share Posted March 22, 2012 We have tried to adjust the rod on the column and can't seem to get anywhere with it,thats what is baffling me,it just don't seem to do anything.... Quote Link to comment Share on other sites More sharing options...
72-CLASSIC_RIDE Posted March 22, 2012 Share Posted March 22, 2012 The linkage bracket on the Transmission may be your problem if using the bracket from the 350 tranny as the 400 & 350 use different brackets. The alignment of the cable may be off giving you the irregular shift pattern. Just a guess? Â Doug Quote Link to comment Share on other sites More sharing options...
bgl0b6 Posted March 22, 2012 Author Share Posted March 22, 2012 I will try to change the bracket tonight,but this is a mechanical linkage,no cables...Thanks,will try that Quote Link to comment Share on other sites More sharing options...
bgl0b6 Posted March 24, 2012 Author Share Posted March 24, 2012 I had to bend the bell crank rod about 1/4'' and it works great...Mike Quote Link to comment Share on other sites More sharing options...
