Shroka Posted June 14, 2012 Share Posted June 14, 2012 When first starting my Monte on full choke the blue smoke (oil) is getting a little thick until she warms up. Is there any quick way to fix this? Additives, synthetic oil etc... Thanks! Quote Link to comment Share on other sites More sharing options...
CrazyDavey Posted June 14, 2012 Share Posted June 14, 2012 synthetic oil would probably make it worse...that's a typical symptom of bad valve guide seals (or worn guides themselves). Really no magic potion for that except a valve job.... Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted June 15, 2012 Share Posted June 15, 2012 synthetic oil would probably make it worse...that's a typical symptom of bad valve guide seals (or worn guides themselves). Really no magic potion for that except a valve job.... How old is the motor? or valve train? that is pretty commen on older heads. Valve seals can be changed without tear down but guides require the heads being removed. Has it gotten bad enough that its fouling the plugs? Wow more questions than answers. Good luck. Quote Link to comment Share on other sites More sharing options...
