nuetral safety and backup light wires
72SinceNew
If I can get this tranny in and working I'll be at the Eastern meet in Hiawassee with the bride of 44 years.
Need help with finding/routing nuetrl saftey and backup light wires - changing frm column to TCI fastgate and using an extreme automatics 200-4R - next will be the lockup kit install - then the TCI TV made EZ kit - then the new exhaust- then test drive but first - what color wires are they?
I thought the back up light wires were Light Green and the other was Pink and yes on the Neutral wires being Purple and the other Purple with White stripe down it..?????
Darren.
Thanks for reply - both of you
I now have an idea of what to look for
I guess if I leave the column shifter as if it's in park and cut those wires to effectively put the little micro swithes of the TCI floor shifter in the cut - it should work. The wires will be Open till the switches make contact with reverse for lights and nuetral/park for safety wires.
That will work for the neutral safety switch, but for the back up light you would have to have both the column shifter and the TCI in reverse!
Now I get it - I think- Cut and route those wires to the shifter instead of steering column - Any more info ?? Next I need to figue how to attach the E brake cable now that the cross member is apprx 6 in. rearward
I think I'll have it done just before Eastern Meet - Thanks for replys guys!
