monte70car Posted July 12, 2012 Share Posted July 12, 2012 On our 57 Chevy we have the stock style rear end pumpkin comes out of the front. The drain plug had started leaking a few years back so we changed it for a rubber type plug and changed the gears from a 3.08 to a 5.13 back to a 3.70, but we torn the rubber plug with the jack. We did but a self threading plug which is a 1/2-20 drilled the hole I think he said 1/2" but the plug wont thread into the housing, a 9/16 drill bit is way to big for the plug. We also picked up a rubber water jacket plug but its to big 3/4" anyone run into a problem like this before? Quote Link to comment Share on other sites More sharing options...
Mike 57 Posted July 13, 2012 Share Posted July 13, 2012 If you bought a 1/2 inch plug I would think that the hole drilled would have to be 15/32 according to the tap drill chart. Unless it is a oversize plug. What is the outside diameter of it? Quote Link to comment Share on other sites More sharing options...
monte70car Posted July 13, 2012 Author Share Posted July 13, 2012 The plug has outside diameter of .540 Quote Link to comment Share on other sites More sharing options...
Mike 57 Posted July 13, 2012 Share Posted July 13, 2012 Sounds like an "oversize" plug, you can try to taper the outside of the hole to get it started. the best bet would to be to take the pig back out, get a regular size 1/2 inch plug an tack a 1/2 jam nut on the inside to hold it. Quote Link to comment Share on other sites More sharing options...
