patman Posted August 8, 2012 Share Posted August 8, 2012 I replaced my broken plastic inner fenders with steel ones and now I can't get my battery tray and support to line back up. I can line up the tray where it needs to be, but the support doesn't even come close to lining up. If I loosely bolt the support on I can get it in the right place, but the tray won't line up. What am I doing wrong? Quote Link to comment Share on other sites More sharing options...
383monte Posted August 19, 2012 Share Posted August 19, 2012 Basically anything that is not OEM will have fitment issues. Quote Link to comment Share on other sites More sharing options...
Mo's70MCs Posted August 19, 2012 Share Posted August 19, 2012 I agree it may require some tweaking, I've never done the steel fender-wells..but when doing so, I do remember they didn't quite line-up well either. Well perfect! It took a lil more effort than I expected, how bad are they off? Quote Link to comment Share on other sites More sharing options...
black07ss Posted August 19, 2012 Share Posted August 19, 2012 Not sure how bad they are off but if you can get the bolts started and you tighten them. It may just spring, bend into place. Quote Link to comment Share on other sites More sharing options...
patman Posted August 20, 2012 Author Share Posted August 20, 2012 The fender wells fit really well. I found out the the support isn't there on the steel ones. That's why it wouldn't fit. So I'm all good to go. Quote Link to comment Share on other sites More sharing options...
