dbreese Posted January 30, 2013 Share Posted January 30, 2013 Was able to use the original case. Don't think I will be cracking this bellhousing. Converter is coming from Coan. Should be here on Fri. David Quote Link to comment Share on other sites More sharing options...
Mike 57 Posted January 30, 2013 Share Posted January 30, 2013 Looks really good Dave. You are going to hate the BOP top mounting ears when you go to put the top bolts in! I had mine machined off when they did my trans. Quote Link to comment Share on other sites More sharing options...
dbreese Posted January 30, 2013 Author Share Posted January 30, 2013 Looks really good Dave. You are going to hate the BOP top mounting ears when you go to put the top bolts in! I had mine machined off when they did my trans. Heck I didn't even catch that!!! CRUD Quote Link to comment Share on other sites More sharing options...
Gonzo Posted January 30, 2013 Share Posted January 30, 2013 Looks good Dave. That should handle your power. At what HP or torque range do they recommend going to an Ultra Bell? Quote Link to comment Share on other sites More sharing options...
Mike 57 Posted January 30, 2013 Share Posted January 30, 2013 It will work out Dave, I just remembered bolting up a later TH350 with the dual pattern in a Monte. So when I was talking to Rossler and he said it was dual pattern I had him cut the BOP ears off. Quote Link to comment Share on other sites More sharing options...
dbreese Posted January 30, 2013 Author Share Posted January 30, 2013 Looks good Dave. That should handle your power. At what HP or torque range do they recommend going to an Ultra Bell? I would guess that if you do any drag racing where you stress the drivetrain and the car is hooking I would think 500hp/500ft lbs. With that being said it is really a good safety feature should you have a converter/flexplate come apart. I think some of my problem is the hp level I wam at coupled with solid motor mounts (ruuber trans mount) led to its demise. I can't tell you how many pass I have made since 2005. A bunch!! It is really cheap insurance. Got it from Coan for $270.00 You can get them through Summit or Jegs also. David Quote Link to comment Share on other sites More sharing options...
dbreese Posted January 30, 2013 Author Share Posted January 30, 2013 It will work out Dave, I just remembered bolting up a later TH350 with the dual pattern in a Monte. So when I was talking to Rossler and he said it was dual pattern I had him cut the BOP ears off. Thanks Mike. Quote Link to comment Share on other sites More sharing options...
680HPStroker Posted January 31, 2013 Share Posted January 31, 2013 Looks awesome David. When my tranny guy istalled the Ultra Bell on my Turbo 400 I don't remember him saying anything about BOP ears. Maybe he just took care of it and did not bother mentioning it. Although I haven't ran the car yet between the bellhousing, 900HP Mid-West Converter(expensive little bugger), and my Carpenter Enterprises lower tranny shield brackets I don't think I'd have to worry to much about the number of passes I make, or how hard I beat the car. I've been told numerous times to replace the driveshaft with an Aluminum SFI one and run this beast as everthing else in the powertrain of my car is ultra strong. Quote Link to comment Share on other sites More sharing options...
AL M Posted January 31, 2013 Share Posted January 31, 2013 Looks great david !!!!! Quote Link to comment Share on other sites More sharing options...
Gonzo Posted February 4, 2013 Share Posted February 4, 2013 Dave thanks for the info. Sounds like something I will look into once I can start the upgrades. Quote Link to comment Share on other sites More sharing options...
502ci Posted February 4, 2013 Share Posted February 4, 2013 Looking good... Quote Link to comment Share on other sites More sharing options...
