Ramon Torres Posted March 10, 2013 Share Posted March 10, 2013 does the beige wire leading to fuel sending unit be hot? Quote Link to comment Share on other sites More sharing options...
footballubet Posted March 10, 2013 Share Posted March 10, 2013 No voltage to the sending unit. The sending unit is just like an ohmmeter and the gauge needle moves according to the reading. Quote Link to comment Share on other sites More sharing options...
Ramon Torres Posted March 10, 2013 Author Share Posted March 10, 2013 thanks Quote Link to comment Share on other sites More sharing options...
wallaby Posted March 10, 2013 Share Posted March 10, 2013 If you put a test light on that wire, it will light up, (dimly) when the key is turned on. Unplug the wire connector near the trunk latch and use the test light in the wire leading to the front of the car. I suspect that if you just stab the light into the wire while it is hooked up, you won't get a result. The resistance in the test light bulb will change the gauge reading on the dash. Quote Link to comment Share on other sites More sharing options...
