monte70car Posted March 19, 2007 Share Posted March 19, 2007 need help on this i got vortec head and a vortec intake i got water pourin out both the front and back on each side. affird to torque it down any more and brake a bolt off. the only thing i didnt put on the bolts was thread lock do u think it would make any differents??? or should they have plumbs tape on the threads? this is goin on a week project now with the same thing from last week. Link to comment Share on other sites More sharing options...
kc8oye Posted March 19, 2007 Share Posted March 19, 2007 do you have the right intake gaskets? as I understand it.. vortec heads/intakes are different.. also.. did you put a small smear of RTV around all the water ports before you put the gaskets in? Link to comment Share on other sites More sharing options...
Guest Posted March 19, 2007 Share Posted March 19, 2007 Are you using the vortec intake gaskets ? The gaskets I used were plastic with the rubber o ring type seals on them. I think the torque specs were only about 10 ft lbs. Also I used genuine GM gaskets, someone told me aftermarket gaskets were leakers. I use a dab of rtv on the bolt threads. Link to comment Share on other sites More sharing options...
monte70car Posted March 19, 2007 Author Share Posted March 19, 2007 i have the gm vortec intake gasket's. i also have the rtv on the front and back chain rail so ill wait for the water to go bad and take the bolts back out and put the rtv on the bolts and see if that helps any. Link to comment Share on other sites More sharing options...
Guest Posted March 19, 2007 Share Posted March 19, 2007 10 lbs doesn't sound like enough does it but trust me don't go any tighter then that and you shouldn't have any problems. Link to comment Share on other sites More sharing options...
monte70car Posted March 19, 2007 Author Share Posted March 19, 2007 the paper work says 11 foot pounds Link to comment Share on other sites More sharing options...
footballubet Posted March 19, 2007 Share Posted March 19, 2007 Yes, torque is 11 lbs. ft. If you have to take the intake off again, check the heads and intake with a straight edge. Someone may have tried to torque to the older specs and tweaked the mating surfaces. Good luck. Link to comment Share on other sites More sharing options...
monte70car Posted March 19, 2007 Author Share Posted March 19, 2007 scott its a fairly new intake bought it in nov. the heads been on the motor since 2001 which at that time had an single panel intake on it which didnt leak. maybe my torque wrench aint any good already broke a bolt last week, and today broke the inch pound torque wrench. on anything project. looks like i will be pullin the intake tomorrow sometime:( i step forward two steps back keep this up the single panel and 600 holley might find its way back on the motor. im headed to the chat room. Link to comment Share on other sites More sharing options...
monte70car Posted March 20, 2007 Author Share Posted March 20, 2007 sealer on the threads didnt work the water is comin out from under the gaskets. probably pull the intake back off later tonight if not tomorrow . scott u think it will be ok to put the rtv around the water jackets? i checked the gaskets that was on it last week and its coming out around the o-rings. its a 355 vortec motor with a vortec tpi base plate. right now im opened to all ideals as this is goin on to a three year project. the vortec heads r 1996-1997 if that helps any. Link to comment Share on other sites More sharing options...
MonteAZBB70 Posted March 20, 2007 Share Posted March 20, 2007 Is it possible that the block has been decked so much that the gasket surface mating angles have changed and the gaskets just won't seal? I've heard of such things, but never seen it. Has anyone here ever had any experience with such things? Mike Link to comment Share on other sites More sharing options...
monte70car Posted March 20, 2007 Author Share Posted March 20, 2007 the single panel that we raned on it for since 2001 never leaked. Link to comment Share on other sites More sharing options...
Guest Posted March 20, 2007 Share Posted March 20, 2007 I have seen the seal bead get rolled out if the manifold was scooted to line up the bolts. I take long 5/16 bolts and cut the heads of so I can slide the manifold straight down. Don Link to comment Share on other sites More sharing options...
monte70car Posted March 21, 2007 Author Share Posted March 21, 2007 hopefully we didnt mess up the gasket went ahead and put the rtv sealer on the intake gasket. found a nick on the head that the intake sits on. Link to comment Share on other sites More sharing options...
monte70car Posted March 21, 2007 Author Share Posted March 21, 2007 well it doesnt look like i got enough rtv on the drivers side passager side aint leakin a drop now. i hope the rtv comes off the intake gasket good. here is a pic of it half apart Link to comment Share on other sites More sharing options...
